Re: Espace II 2.1 td de 95 de Grizzly Sauvage
Sur l'emballage il y à écrit 24V mais sur le site (Italie) c'est bien 12/24V
Brun's
string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "16343" string(5) "16343" string(5) "16343" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490" string(5) "19490"
Site d'entraide de passionnés de Renault Espace
https://www.passion-espace-club.com/
Oui vu le porte gobelet... je cherche ( sans vraiment chercher, les idées viennent pendant le sommeil ) un système discret pour installer a la place du cendrierGrizzly Sauvage a écrit : j'ai comme souvenir que la voiture de mon père au Canada (Montréal) une "Nova" avait même de série un extincteur!![]()
D'ailleurs tu là peu être remarqué, sur la photo ou j'ai la prise 12V j'ai aussi un "porte gobelet rétractable" installé dans la console centrale, sous l'auto-radio![]()
Salut,pontiac a écrit :Salut,
Plus d'une décennie d'avance les US![]()
Oui !elles maintiennent le tambour .☺camion rouge a écrit :Salut
Pour sortir le tambour, d'habitude on ne retire QUE ces vis !
Dan
Dan
Salut,camion rouge a écrit :Salut
Dan
Vu, merkip23 a écrit :Oui !elles maintiennent le tambour .☺camion rouge a écrit :Salut
Dan
Oki, pour le tournevis à frappe, pas de problème, j'en avait acheter un pour démonté mes disques avant sur mes autres caissespontiac a écrit :camion rouge a écrit :Salut
Dan
Il n'y a pas besoin de virer l’écrou du moyeu pour enlever le tambour... juste les 2 torx, ainsi le moyeu reste en place
Attention ! parfois ces 2 torx sont très bien serrées...
J'en ai foiré pas mal avant... d'investir dans un tournevis à frapper => plus aucunes vis foirées et seulement une dizaine d'euros à l’époque chez Bricodep"
Sinon pour les pièces récupérées... bah yapluka![]()
Merci, je trouve aussiorval56 a écrit :il est mieux là...ton 2.2i
je vérifierai tout ça, par contre je vais devoir me racheter une clef à bougie (je l'avait donner avec ma 19 16s)pontiac a écrit :Salut,
Pour le 2.2i...
Voit si les fils de bougies sont OK ( oxydation, jeu, fuites )
Doigts de la bobine ( oxydation )
État des bougies
Sinon il est fort possible que le filtre soit en partie colmaté, dans ce cas ATTENTION de ne pas flinguer la pompe![]()
Aussi possible que des impuretés soient arrivées au niveau injecteurs...
Et le temps que le réservoir est vide... profite de çà pour le déposer, nettoyer, vérifier / régler la jauge
Heu... ça fait beaucoup de choses courantes sur un (2.2i) quand même làp23 a écrit :Pour les défauts,rien que des choses courantes sur un Espace 2 !![]()
. Aprés la remise en état ,et vu qu'il est rester longtemps sans bouger,risque de faire apparaître encore quelques surprises !
Maintenant vu la mise de départ et en y allant progressivement (tu n'es pas obligé de tout faire a la fois).......pourquoi pas.![]()
Sur le mien,j'ai eu également des choses non prévues au début !![]()
Maintenant la décision ne tient qu'a toi,tu es seul juge,pas de soucis![]()
Heu comment dire, pendant une demi heure, tu ma laisser sans motscamion rouge a écrit :Pour l'instant, a part le joint de pare brise , et les manivelles de TO, j'ai tout ce qu'il te faut!
Par contre , vu la taille du capot, il faudra venir chercher tout ça chez moi !
(40km de Montpellier !)
Dan
quand je vois sur LBC le prix des pièces que demande les vendeurs, tu ma vraiment laisser sans voixcamion rouge a écrit :Evidamment c'est cadeau !
De toutes façons, ça doit partir a la casse !!!
