string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" string(5) "18080" Passion Espace Club • réfection boite de vitesse MA sur 307 1.6 essence
Publié : 06 mars 2015, 23:45
par vincenzi1
Comme ici sur le forum beaucoup de personnes aime les reportages photo, je vais donc vous en faire un sur la réfection d'une boite de vitesse
sa va consister au démontage de la boite pour replacement des 6 roulements
aujourd'hui préparation pour tombé la boite
il reste 1 seul vis,travaillent samedi et dimanche, la suite la semaine prochaine
Re: réfection boite de vitesse MA sur 307 1.6 essence
Publié : 09 mars 2015, 21:31
par vincenzi1
suite des hostilités
on emploie les gros moyen
démontage pignon de 5eme
démontage du reste
on sort l'ensemble après avoir demonter la commande de marche arrière et le sélecteur principal
demain je fait les roulements
mes il me manque une douille torx que j’achèterai demain, pour le démontage de la plaque pour avoir accès au différentielle
Publié : 09 mars 2015, 21:45
par Davidrwt
Beau travail, j'avoue le tracteur :lol: :wink:
Publié : 10 mars 2015, 20:45
par vincenzi1
suite à un contre temps familiale j'ai pas pu beaucoup avancés aujourd'hui
Publié : 10 mars 2015, 22:23
Davidrwt a écrit :Beau travail, j'avoue le tracteur :lol: :wink:
.... ça c'est du cric hydraulique breveté nord américain roulant sur pneumatiques :wink:
Publié : 11 mars 2015, 22:27
par vincenzi1
on continue comme j'ai reçu ma torx manquante
on sort les bagues
les rroulements
on passe a la cuisine lol pour remonter les roulements plus facilement on chauffe l'huile de boite de la vidange à 100°(merci la plaque a induction qui permet de régler la température directement)
on chauffe les roulements et on remonte tout
Publié : 11 mars 2015, 22:30
par vincenzi1
suite
et on remonte la plaque avec un coup de loctite sur les vis et serrage au couple
c'est tout pour aujourd'hui
Publié : 11 mars 2015, 22:32
par Pilou29
Que c'est beau et que çà parait facile :D mais pas à la portée du premier bricoleur venu !
Beau travail, continue comme çà on adore les reportages photos :wink:
Publié : 11 mars 2015, 22:48
par vincenzi1
Pilou29 a écrit :Que c'est beau et que çà parait facile :D mais pas à la portée du premier bricoleur venu !
merci pour les encouragement Philou29
Publié : 13 mars 2015, 18:20
par denis54
hello,
pppffiiiooouuuuuu.... m'énerves.... :mrgreen:
dis tu veux pas déménager prés de NANCY, je viendrais te donner un coup de main :mrgreen:
ça parait tellement simple.. j'aimerais tellement savoir faire ça 8)
beau boulot et très beau "cric" :mrgreen: :lol:
denis
Publié : 13 mars 2015, 21:41
par vincenzi1
on fini de remonter tout et on termine par des joints neuf
La boite et remonter dans la voiture
il me reste a mettre de l'huile, support batterie, les roues, et quelque bricole
tout sera fait lundi suivie d'un teste sur route
Publié : 13 mars 2015, 21:47
par vincenzi1
denis54 a écrit :hello,
denis
bonjour Denis,
tu sais que je suis lorrain de naissance et que avant la Normandie depuis un peut plus de 3 ans j’habiter à Joeuf (30km de metz) :lol:
Publié : 13 mars 2015, 22:22
Beau boulot ;)
Publié : 14 mars 2015, 13:15
par Davidrwt
Bravo, impeccable tout ça :wink:
Publié : 14 mars 2015, 16:41
par denis54
denis
bonjour Denis,
haaaaaa... :mrgreen: bon alors comme on retourne toujours sur les lieux de son enfance on va te voir par ici un jour :mrgreen: :lol:
on parlera de la E39 530D j'en ai eu une aussi :oops:
continue les photos reportages moi et beaucoup ici aiment ça :oops:
au plaisir
denis
Publié : 16 mars 2015, 20:50
par vincenzi1
Essai sur route concluent plus de bruit de roulement :)
Publié : 16 mars 2015, 21:35
par Davidrwt
Beau travail pour pas très cher en plus :roll:
Publié : 16 mars 2015, 21:56
vincenzi1 a écrit :Bonjour,
Félicitations pour le boulot, et pour le résultat en plus :)
Publié : 17 mars 2015, 12:18
par anciensafraniste
Chapeau bas l'ami :wink: :wink: :wink:
en plus les boites de vitesses c'est vraiment special :!: :!:
Beau travail :!: :!: :!:
Publié : 17 mars 2015, 23:14
par vincenzi1
Davidrwt a écrit :Beau travail pour pas très cher en plus :roll:
merci @ tous pour les félicitations :)
le coup de la réparation est de 169 euros port compris pour info :) est une 20 ene d'heures de taff tranquillement :roll:
Publié : 18 mars 2015, 09:04
par pontiac
Beau boulot, bravo :!: :wink:
