Peut on rouler avec des sieges dos a la route ???
Bonjour .
Je voulai savoir si on pouvai rouler avec des sieges arriere dos a la route ?
Il y as une ceinture ventrale pour chacun des 2 sieges dos a la route .
[color=#32CD32]E[/color][color=#43CA2E]s[/color][color=#54C62A]p[/color][color=#65C326]a[/color][color=#76C021]c[/color][color=#87BC1D]e[/color] [color=#AAB615]3[/color] [color=#CCAF0D]R[/color][color=#DDAC08]X[/color][color=#EEA804]E[/color] [color=#FF9700]2[/color][color=#FF8A00].[/color][color=#FF7C00]2[/color] [color=#FF6000]D[/color][color=#FF5300]T[/color] [color=#FF3700]d[/color][color=#FF2900]e[/color] [color=#FF0E00]9[/color][color=#FF0000]8[/color]
[color=#32CD32]G[/color][color=#3FCA2F]o[/color][color=#4CC82C]l[/color][color=#5AC528]f[/color] [color=#74C022]3[/color] [color=#8FBB1B]c[/color][color=#9CB818]a[/color][color=#A9B615]b[/color][color=#B6B312]r[/color][color=#C3B10F]i[/color][color=#D1AE0B]o[/color][color=#DEAB08]l[/color][color=#EBA905]e[/color][color=#F8A602]t[/color] [color=#FF9500]1[/color][color=#FF8A00],[/color][color=#FF8000]8[/color][color=#FF7500]L[/color] [color=#FF6000]9[/color][color=#FF5500]0[/color][color=#FF4B00]c[/color][color=#FF4000]h[/color] [color=#FF2B00]d[/color][color=#FF2000]e[/color] [color=#FF0B00]9[/color][color=#FF0000]4[/color]
[color=#32CD32]M[/color][color=#46C92D]é[/color][color=#59C528]g[/color][color=#6DC224]a[/color][color=#80BE1F]n[/color][color=#94BA1A]e[/color] [color=#BBB211]c[/color][color=#CEAF0C]o[/color][color=#E2AB07]u[/color][color=#F5A702]p[/color][color=#FF9D00]é[/color] [color=#FF7E00]1[/color][color=#FF6E00].[/color][color=#FF5E00]6[/color][color=#FF4F00]e[/color] [color=#FF2F00]9[/color][color=#FF1F00]0[/color][color=#FF1000]c[/color][color=#FF0000]h[/color]
[color=#32CD32]4[/color][color=#43CA2E]x[/color][color=#54C62A]4[/color] [color=#76C021]B[/color][color=#87BC1D]e[/color][color=#99B919]r[/color][color=#AAB615]t[/color][color=#BBB211]o[/color][color=#CCAF0D]n[/color][color=#DDAC08]e[/color] [color=#FFA500]F[/color][color=#FF9700]r[/color][color=#FF8A00]e[/color][color=#FF7C00]e[/color][color=#FF6E00]c[/color][color=#FF6000]l[/color][color=#FF5300]i[/color][color=#FF4500]m[/color][color=#FF3700]b[/color][color=#FF2900]e[/color][color=#FF1C00]r[/color] [color=#FF0000]2[/color]
[quote="sam007";p="81407"]même pas le siège conducteur ? [/quote]
Si, mais uniquement en marche arrière...
[url=https://www.passion-espace-club.com][img]http://www.spproust.net/userbars/userbar-pecuser.png[/img][/url]
[s]Espace IV 2.2 DCI Expression de 2004 - 141000 km - boite 6 manuelle - acheté en janvier 2009[/s], c'était mon 1er... et sans doute dernier Espace !
[quote="nonogt";p="81408"]me suis toujours demander pourquoi c'est interdit, en cas de choc frontal, c'est plus sur, non?[/quote]
Oui mais tu te prends tout le reste dans la tronche
C'est effectivement interdit, pour des raisons de structure du siège, en cas d'accident frontal , du coup, c'est ton siège qui amortit tout tout le poids et pas ta ceinture , et il est loin d'être capable de digérer les 10 G avec 75 kilos il n'est pas conçu pour cela ... déja que l'armature ne digère pas le déclenchement d'un air bag latéral et en plus le coup du lapin est encore plus tueur si tu as mal mis ton appui tête
Re: Peut on rouler avec des sieges dos a la route ???
J'ai le livret d'utilisation d'origine .
Il est justement précisé page 1.05 dans l'encadré intitulé IMPORTANT :
" Lors des déplacements du vehicule , les sieges utilisés doivent imperativement etre en position permettant la mise en place et l'utilisation normale des ceintures de sécurité . "
Je possede 2 ceintures ventrales a 2 points d'attache , donc si on regarde le paragraphe que j'ai cité on peut se servir noralement des ceintures ...
Pour la solidité des sieges qu'ils soient dos a la route ou face a la route dans tous les cas les ceintures y sont fixées ( les ceintures a 3 points en on 2 de fixées sur le siege ... ) donc en cas de choc il y aura le meme effort sur le siege dans un sens ou dans l'autre ...
Je pensai a mettre les sieges dans cette position pour faire genre " petit salon " pour mes enfants . Un copain qui avai un vieu VW 7 places avai justement tourné la banquette du millieu dos a la route . Niveau convivialité a bord c'est plutot sympa ...
PS : je parlai de rouler avec les sieges de la rangée du millieu dos a la route ... c'est vrai que pour ce qui est du siege conducteur ça doit quand meme etre beaucoup moins pratique
Non justement, les contraintes ne vont pas dans le même sens, loin s'en faut... en cas de choc frontal les sièges orientés vers l'avant, ils travaillent en "décharge", ils sont à vide sur la décélération la plus violente. A l'inverse, ils sont en "charge" tu as le poids du corps en plus, et là les armatures souffrent beaucoup plus ... et quand tu vois comment cela bouge sur les crash tests en décharge, je te laisse imaginer avec le poids du corps en plus en appui
C'est le systeme de fixation rapide des sieges qui ne suporterai pas ou carement la structure ?
Vu le poid que fait chaque siege je pensai que c'etait un peut plus solide
- patespace
nico,
suite à un tete à queue sur la route, a grande vitesse (150 environ), j'ai percuté un arbre en "marche arrière".....
le siege (je parle du dossier) de ma xsara à été pulvérisé!
j'ai de la chance de t'en parler....... car on ne sait pas comment je m'en suis sorti!
bref, la structure du siege ne doit pas etre prévu pour ça, et moi à ta place, je ne tenterai pas le
Ok , merci pour ces infos
Ca m'evitera de faire n'importe quoi ...
- romop36
- finition : RT
- Année : 1997
Lorsque je trainais avec des copains cascadeurs, ils avaient tellement confiance aux sièges, qu'ils renforçaient et attachaient les armatures avec du fil de fer gros modele
Thierry
espace II RT turbo D 1994
espace 2000 TSE 1986
http://www.matra-passion.com
